Lr4 electrical issues, hvac, infotainment speedometer not working
Hows everybody doing? I'm a long time lurker and first time poster from NYC
I have a 2010 Lr4 hd hse v8 with 105000 miles which i owed for 6 years, I do my own maintenance (oil change, brake rotor, brake pad, alternator)
My car starts and drives with no issues but the instrument cluster, hvac, radio system, parking assist, etc doesn't work at all.
I refused to bring the car to the dealer but this time i might have to if i cant fix the issue. Any help will helpful. Thank you
The car was neglected for a few years and had a sunroof leak which i believe caused a lot of issues.
So what i did to the car is far
sunroof leak is repaired,
replaced the battery with h8 interstate agm, changed ccf battery type with iidtool
replaced alternator with a new denso dan1103
checked the ground points and bcm connectors.
Here are the fault list given from the IIDTOOL BT
VIN SALAM2D40AA538073
Model L319 - LR4 2010
Vehicle scanned on Jun 28, 2022 9:36:10 AM
IIDControl 3.0.0 Build 84 Android - IIDTool BT V3.0 B2742
ACM-Audio System
U0140-00 (2B) Lost communication with body control module
( on 08-01-2024 00:53:17 at 0 mi )
U0159-00 (2B) Lost communication with parking assist control module
BCM-Body Control
U0155-00 (2F) LCD Gauge Communication Lost
( on 28-06-2022 09:35:28 )
U0164-00 (2F) Lost communication with heating ventilation and air conditioning control module
U0184-00 (2F) Lost communication with audio unit
U025D-00 (2F) Lost communication with front controls interface module B
FCIM-HVAC Buttons
U0140-00 (2F) Lost communication with body control module
U2100-00 (2F) Initial configuration is not complete
FCIMB-Audio Buttons
HVAC-Ventilation
B1081-00 (6C) Left temperature damper motor
B1082-00 (6C) Right temperature damper motor
B1085-00 (6C) Defrost damper motor
B1086-00 (6C) Air distribution damper motor
B1B7B-00 (6C) Air blend actuator - Rear left
B1B7D-00 (6C) Air distribution actuator - Rear
U0140-87 (6C) Lost communication with body control module - Bus signal/message failure - missing a message
U3000-87 (6C) Control module - Bus signal/message failure - missing a message
IPC-Instrument Pack
B1A85-96 (2F) Ambient light sensor circuit - Component failure - internal failure
U0402-68 (2F) Invalid data received from transmission control module - Algorithm based failure - event information
U3000-87 (2F) Control module - Bus signal/message failure - missing a message
ACM-Audio System
BCM-Body Control
FCIM-HVAC Buttons
FCIMB-Audio Buttons
HVAC-Ventilation
IPC-Instrument Pack
Ian Mitchell
12-16-2019 05:33 PM
Friday Night Disco
05-26-2019 08:54 PM
y2motoskier
04-28-2012 02:45 PM
y2motoskier
04-28-2012 02:31 PM
