LR4 Signature LED
Old Apr 6, 2012 | 11:44 AM
jLR4's Avatar
6th Gear
Default LR4 Signature LED
Hi, very new to this, but maybe someone can help me out please.
I just purchased a 2012 LR4 HSE LUX and I noticed in some pictures their signature LED lights are on without the regular lights.
Could anyone tell me how I can get the signature LED lights to run as DRL’S ( day time running lights) without the regular lights to come on.
Is there something I can do, or something I can pass on to the Land Rover tech.
Thanks
Old Apr 7, 2012 | 12:49 PM
LeFils's Avatar
4wd High
Thanks
The dealer should be able to "reprogram" the lamps to have the daytime running lights (DRL)without the headlight beam on. The DRL in my 2010 LR4 unfortunately has the headlights on but it was fixed in later models. I know that for sure because a friend of mine has a 2012 LR4 and the DRL works exactly as you state they should.
Old Apr 7, 2012 | 03:30 PM
Fotogr4's Avatar
Yep, it's a computer setting. Dealer can do it, or perhaps a buddy with a computer that can talk to your LR4.
Old Apr 7, 2012 | 03:47 PM
jLR4's Avatar
6th Gear
Thanks LeFils and Fotogr4.
Old Apr 25, 2012 | 07:35 AM
jLR4's Avatar
6th Gear
Went to dealer today to see if they could setup signature lights as running lights, service says only with both main headlights and signatures. Does anyone know how I can run signature lights as running lights? Or recommend someone I can talk to about this. Thanks
Old Apr 26, 2012 | 08:46 AM
LeFils's Avatar
4wd High
I have some concerns about your dealer, and you should too!!!
I was quite intrigued and just called Land Rover to verify the DRL feature in the 2012 LR4 model; they call them "Halo Lights." They again confirmed that once you start the vehicle and the gear is shifted out of "P" the Halo Lights are automatically on without the headlight beams. If that doesn't occur the dealer should be able to reprogram them.
I suggest you again go back to the dealer and have them call Land Rover in your presence to verify this. Their number is 800-637-6837.
Good Luck!
Old Apr 27, 2012 | 08:39 AM
jLR4's Avatar
6th Gear
Thank You LeFils I will do that.
And again thank you!!
Old Apr 30, 2012 | 02:27 AM
BD_LR4's Avatar
LeFils,
I've got a 2010 as well. Have you checked back to see if they made this programming change as a software update to the 2010? I'd be curious to know because I would love to do that with mine as well. For now, I just turn on the AUX lights to get the LED's on.
I know they added programming for some of the new off-road capabilities introduced in 2011 - like the Hill Start Assist. This wasn't available in 2010, but when the 2011's came out it was new. Since then, the dealership updated the software and I now have Hill Start Assist (as tested off-road on several climbs).
Thanks for the great info - keep it coming!
Old Apr 30, 2012 | 08:33 AM
LeFils's Avatar
4wd High
Hi BD ... for the 2010 LR4 HSE LUX PLUS model take a look at page 74 of your owner's manual. It does tell you that the dealer can program the low beam headlamp to serve as daytime running lamp, which is what I had done in mine. Once programmed the low beam headlights and halo lights will turn on when you shift out of "P" whether the lamp master switch is off or in automatic mode.
Old May 4, 2012 | 02:12 AM
BD_LR4's Avatar
Thanks LeFils. I had tried that several year ago and was hoping to get just the halo lights, hence my comment about potential software upgrades applied to previous year models. If you do find out something different, please let me know.
