Here is how the new 255-65-19 (32 inches) looks with our 3.0 front kit shown in off road mode and then normal mode.
This is a good tire option as the narrower stock width tire fits the LR4 well.
Check our links below to order a set.
255-65-19 (32 inches) Goodyear Duratracs with our 3.0 front lift kit.
This has become a very popular set up for those with the 19 inch wheels.
If you have 20's you can run the same tire in 255-60-20. These tires were build
specifically for the Land Rover Defender and are perfect for the LR4 and LR3.
Check our our profile in the links below @johnsonrods
Looks good! With the bigger sidewall, did you get a johnson lift? If so, how high? I would like to keep my stock rims as well and put more rubber on with a 1.5 lift...
We are seeing a lot of the Johnson Rod 3.0 kits combined with the 255-65-19 (32") tire.
Because of the stock width, if fits where other 32's may rub.
Here is another example: 255-65-19
The 1.5 inch lift if commonly used with a slightly larger tire than stock. This is a good way to get some added lift for those not wanting to go too high.
A very popular set up is with 18" wheels and 265-65-18.
