LR4 Tire Size Chart
Old Jan 17, 2021 | 09:21 PM
  #21
Kelvis80's Avatar
Hi!!! and how is gas consumption going? decrease mpg much??
Old Jan 18, 2021 | 02:46 PM
  #22
Johnson Rods's Avatar
LR Forum Vendor
Here is how the new 255-65-19 (32 inches) looks with our 3.0 front kit shown in off road mode and then normal mode.
This is a good tire option as the narrower stock width tire fits the LR4 well.
Check our links below to order a set.
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Mar 2, 2021 | 12:58 PM
  #23
LR Forum Vendor
255-65-19 (32 inches) Goodyear Duratracs with our 3.0 front lift kit.
This has become a very popular set up for those with the 19 inch wheels.
If you have 20's you can run the same tire in 255-60-20. These tires were build
specifically for the Land Rover Defender and are perfect for the LR4 and LR3.
Check our our profile in the links below @johnsonrods
__________________
Old Mar 11, 2021 | 04:06 PM
  #24
LR Forum Vendor
265-65-18 BFG's with Compomotive wheels found on our website:
__________________
Old Apr 3, 2021 | 08:25 AM
  #25
pdacquel's Avatar
Originally Posted by Fritzerland
And a few more shots.
Looks good! With the bigger sidewall, did you get a johnson lift? If so, how high? I would like to keep my stock rims as well and put more rubber on with a 1.5 lift...
Old Apr 19, 2021 | 12:59 PM
  #26
mandrake15's Avatar
Any rubbing or trimming necessary to the liner or frame horns with the 255/65/19's?
Old Apr 27, 2021 | 11:26 AM
  #27
LR Forum Vendor
We are seeing a lot of the Johnson Rod 3.0 kits combined with the 255-65-19 (32") tire.
Because of the stock width, if fits where other 32's may rub.
Here is another example:
255-65-19
__________________
Old Apr 27, 2021 | 11:40 AM
  #28
LR Forum Vendor
The 1.5 inch lift if commonly used with a slightly larger tire than stock. This is a good way to get some added lift for those not wanting to go too high.
A very popular set up is with 18" wheels and 265-65-18.
__________________
Old May 15, 2021 | 06:23 PM
  #29
LR Forum Vendor
Nice LR3 with our 3.0 front lift running 265-65-18. For the LR4 this tire size works with the 1.5, 3.5 and 3.0
Follow our links below for more info.
Before and after using our 3.0 Johnson Rod lift with 265-65-18 tires.
__________________
Old May 18, 2021 | 09:27 PM
  #30
Fritzerland's Avatar
5th Gear
No Lift kit. Straight stock and no rubbing.
