LR4 Tire Size Chart
#51
Going Big with Johnson Rods 3.0 lift kit
Check out all our lift options and great wheels for your LR3 and LR4
Johnson Rods Lift Kit and Wheels
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
#53
Found a new wheel and tire setup!
I know it’s hard to find tire and wheel combos for our vehicles but I found a new setup that works great.
Not sure why these pics are side ways but you get the idea. Found a set of Fuel 18” off road wheels (rated at 2200 lbs each, more than the factory LR wheels) and Nitto Ridge Grapplers 275/65/18. Had to use some 30mm spacers and the usual frame horns and plastic trimming. I can include links for all the pieces if anyone is interested. The wheels were only $250 each from Discount Tire Direct on eBay and I found the tires on eBay as well for around $175 each. A total steal! This LR4 is a 2012. I also have a custom wheel setup on my 2008 LR3.
#54
What tire?
#55
#58
#59
Rubbing on 355/66r19 2013 LR4
I just put same tires on my 2013 LR4, having just out proline 2inch plus Johnson Rods on. However at full turn I am getting rubbing in front wheel wells (near back of well on the frame). It’s about a 1/2 inch of rub.
I’m putting on 30mm spacers on in the hope that this solves it.
dis you have any rubbing and if yes, how did you address? Or was 3” lift all the difference (1inch more than what I have on now).
#60
LR4 with our 3.0 Johnson Rod lift plus GAP to run 265-70-18 BFG tires.
Looks Great!
Looks Great!
__________________
