LR4 Tire Size Chart
Old Sep 5, 2022 | 03:30 PM
  #51
Johnson Rods's Avatar
LR Forum Vendor
Going Big with Johnson Rods 3.0 lift kit
Check out all our lift options and great wheels for your LR3 and LR4
Johnson Rods Lift Kit and Wheels
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Oct 16, 2022 | 06:45 AM
  #52
preetsarai's Avatar
Originally Posted by Fritzerland
And a few more shots.
I have a similar setup. What tire pressure do you run? Whatever is on the door sticker for 255/55r19 size or higher?
Old Oct 23, 2022 | 07:00 PM
  #53
TCPeedo's Avatar
6th Gear
Default Found a new wheel and tire setup!
I know it’s hard to find tire and wheel combos for our vehicles but I found a new setup that works great.
Not sure why these pics are side ways but you get the idea. Found a set of Fuel 18” off road wheels (rated at 2200 lbs each, more than the factory LR wheels) and Nitto Ridge Grapplers 275/65/18. Had to use some 30mm spacers and the usual frame horns and plastic trimming. I can include links for all the pieces if anyone is interested. The wheels were only $250 each from Discount Tire Direct on eBay and I found the tires on eBay as well for around $175 each. A total steal! This LR4 is a 2012. I also have a custom wheel setup on my 2008 LR3.
Old Oct 25, 2022 | 03:35 PM
  #54
R.MATTHEW's Avatar
Default What tire?
Originally Posted by johnson rods
here is how the new 255-65-19 (32 inches) looks with our 3.0 front kit shown in off road mode and then normal mode.
This is a good tire option as the narrower stock width tire fits the lr4 well.
Check our links below to order a set.
what tire is that?
Old Oct 31, 2022 | 04:35 PM
  #55
R.MATTHEW's Avatar
Originally Posted by Johnson Rods
275-55-20 with 3.0 lift kit from Johnson Rods
Johnson Rods with 275-55-20 Nitto Ridge Grapplers
can you go with this tire in a 275/60/20?
Old Nov 5, 2022 | 09:57 AM
  #56
preetsarai's Avatar
Default 255/60R19 - no lift or rubbing
I’ve been running a slightly taller tire in 255/60R19 size. Not many 19” A/T options but Toyo Open Country with the 3PMSF rating look amazing IMO.
Old Dec 26, 2022 | 08:49 AM
  #57
Jkm10388's Avatar
Really really naive question, but what brand tyres come standard with the Discovery 4 when new? I bought mine second hand and have GY Eagles
Old Jan 2, 2023 | 07:18 PM
  #58
dkearin's Avatar
4th Gear
Hi! Which of your lift kits gives the equivalent lift as when I set the ride height to the high setting? 1.5"? I'm trying to decide whether to buy the 1.5 or 2.5 kit and I'd like to get a visual of what it will look like at "normal" height after the lift. Thanks!
Old Aug 7, 2023 | 10:41 PM
  #59
Hugoa2's Avatar
Default Rubbing on 355/66r19 2013 LR4
Originally Posted by Gunners01
I just put same tires on my 2013 LR4, having just out proline 2inch plus Johnson Rods on. However at full turn I am getting rubbing in front wheel wells (near back of well on the frame). It’s about a 1/2 inch of rub.
I’m putting on 30mm spacers on in the hope that this solves it.
dis you have any rubbing and if yes, how did you address? Or was 3” lift all the difference (1inch more than what I have on now).
I have the same rubbing and was going to do the 30mm spacers as well. (makes no difference with lift kit). Will the 30mm spacers be enough? Will I have any issues with the original lug nuts poking through the spacers? Ill let you know how it turns out of no one else has said it yet??
Old Aug 13, 2023 | 11:05 AM
  #60
LR Forum Vendor
LR4 with our 3.0 Johnson Rod lift plus GAP to run 265-70-18 BFG tires.
Looks Great!
__________________
