Misfire in 3 and 7
Old Jan 17, 2023 | 09:21 PM
mooni's Avatar
Default Misfire in 3 and 7
Hello everyone. I have been on the forum for a while. I normally check out the updates. But I am in a pickle. I have a 2011 lr4 5.0. I have owned it since 30k miles. It now has 104k miles. It was running rough so I replaced all the 100k stuff (injectors, spark plugs, coil packs, Pcv valves). Now I get a restricted performance and misfire on 3 and 7. Does anyone have and advise or guidance?
Old Jan 18, 2023 | 10:52 AM
Errant's Avatar
I was getting the occassional P0316 and P0307 on warm starts.Take a look at Service Bulletin LTB00409NAS4. Luckily, mine was covered under extended warranty.
Old Jan 18, 2023 | 05:49 PM
mooni's Avatar
Thanks for the reply. I will check it out. The problem is it was not there before I disassembled everything for the tune up. I
Old Jan 19, 2023 | 12:32 PM
Errant's Avatar
Then I would go back and double check that you have everything seated properly on 3 and 7. I know that side was a tight squeeze, sorry.
Old Jan 20, 2023 | 05:46 AM
mooni's Avatar
So I went back and pulled injectors 3,5, and 7. I tested each one with my multimeter and found injector 3 to be the culprit. Thanks for all the advise.
akafred
LR4
Apr 11, 2022 06:20 AM
ImmaSellThisThing
Oct 4, 2021 01:52 PM
Macon B. Norris
Jan 17, 2013 01:26 PM
maxman
Dec 28, 2010 08:40 AM
dammad
Nov 10, 2010 04:55 PM
