my new lr4 has no compression
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
Hey Gang I'm a new LR4 owner...???
and so far I'm a little perplexed!!!
ok here it goes..
I'm pretty handy !st off. so I bought a 2010 LR4 from Copart ( an aution site ) My Bad!!!!!!!
my main situation is NO COMPRESSION or very little.
1st I put a brand new Battery in. ( old one would not hold a charge for more then 2 cranks )
2nd It now turns over but the motor just spins. I can see the timing chain spin looking into the oil fill and the fan spins but oddly NO RPMS REGISTER needle goes up just a tab.
I also squirted Starer Fluid down the air intake.. No Firing
3rd Ran the scanner from the shop across the street NO COEDS (Figured i just replaced battery and cleared all)
4th I pulled the easiest to get to spark plugs (drivers side front 2 closest to the fan) put a compression tester on them the most forward measured only 15 PSI and the second one only 5 PSI
At first i thought i needed a camshaft positiing sensor but now no compression ???????
any Help would be much appreciated
Jay Jay
ok here it goes..
Jay Jay
