my new lr4 has no compression
Old Feb 3, 2020 | 10:47 PM
jayjay115's Avatar
4th Gear
Question my new lr4 has no compression
Hey Gang I'm a new LR4 owner...???
and so far I'm a little perplexed!!!
ok here it goes..
I'm pretty handy !st off. so I bought a 2010 LR4 from Copart ( an aution site ) My Bad!!!!!!!
my main situation is NO COMPRESSION or very little.
1st I put a brand new Battery in. ( old one would not hold a charge for more then 2 cranks )
2nd It now turns over but the motor just spins. I can see the timing chain spin looking into the oil fill and the fan spins but oddly NO RPMS REGISTER needle goes up just a tab.
I also squirted Starer Fluid down the air intake.. No Firing
3rd Ran the scanner from the shop across the street NO COEDS (Figured i just replaced battery and cleared all)
4th I pulled the easiest to get to spark plugs (drivers side front 2 closest to the fan) put a compression tester on them the most forward measured only 15 PSI and the second one only 5 PSI
At first i thought i needed a camshaft positiing sensor but now no compression ???????
any Help would be much appreciated
Jay Jay
Old Feb 4, 2020 | 04:36 PM
DakotaTravler's Avatar
To me that seems like a timing chain failure/jumped timing.
Old Feb 4, 2020 | 11:32 PM
jayjay115's Avatar
4th Gear
Hey Dakota thanks for your input. so I'm assuming i probably have some bent valves that go along with that.
does it mess up the heads..
timing would need to be completely reset..
ughhhh..
Old Feb 5, 2020 | 10:49 AM
I would suggest verifying timing and maybe taking a video scope inside a cylinder. I've not worked on that engine, but most can be verified with a valve cover removed to check cam positions against crank position.
Old Feb 5, 2020 | 01:00 PM
jayjay115's Avatar
4th Gear
thank you D.
much appreciated.
Jay
Old Feb 11, 2020 | 09:24 AM
GemelRover's Avatar
One of your heads has bent valves, you'll need to determine which bank (side) it is on. Do a compression test on each side. Replace bent valves, headgaskets, timing chain & related components.
Old Feb 11, 2020 | 11:19 AM
jayjay115's Avatar
4th Gear
ugh thanks
looking forward to the repair
LeakyDisco
LR4
Feb 10, 2018 01:07 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
tranmkp
LR4
Jan 17, 2017 10:27 PM
EC2TX
LR4
Sep 14, 2014 09:54 PM
pfcboi
LR4
Jan 9, 2014 01:09 PM
