OBD2 scanner for DPF check
Old Jan 25, 2020 | 07:18 AM
Col13's Avatar
Default OBD2 scanner for DPF check
Hi, Newbie alert! Just jumped into the Disco 'ecosystem' with a Disco 4 (2013)....
Been reading a lot about the DPF and potential issues. I've also read that some OBD2 scanners can check the DPF to see if it's filling up or keeping itself clean. We use the car regularly for short journeys and then intermittedly for long journey.
I want to get a scanner that will tell me how full the DPF is getting so I can make sure we avoid problems by doing longer journeys to help keep the DPF clear.
Does anyone have experience of a scanner that will do this? can you recommend a scanner, or which ones to avoid?
Thanks in advance,
(Newbie) Col
okdiscoguy
Jan 16, 2024 04:31 PM
yorocky
May 17, 2014 04:55 AM
