P0480 and P0526 codes thrown after water pump replacement - input appreciated!
Old 09-25-2020, 03:29 PM
Jason08's Avatar
Default P0480 and P0526 codes thrown after water pump replacement - input appreciated!
Hi everyone:
​​​​​​My 2011 LR4 has about 125k miles. I just replaced the water pump and front crossover pipe (*big thanks to those that posted those guides!).
The installation was relatively smooth. Upon starting the car, I received the "Restricted Performance" message on my dash.
I pulled the codes with a basic Accutron obd reader and the following were noted:
P0480 and P0526.
They both seem to be related to the fan. The fan was working fine before.
so far I've done the following:
- checked the fuse and it has continuity
- checked the voltage on the battery and got the full 12.7 volts at rest.
- unplugged and replugged the fan harness on the plastic fan shroud
- left the car with the negative battery terminal removed overnight
I don't think the fan clutch is bad since it was working fine prior to this repair. Can anyone suggest anything else I can try to diagnose and/or resolve this issue.
Any input is sincerely appreciated.
Thanks!
Old 02-16-2023, 12:56 AM
Rossp100's Avatar
Originally Posted by Jason08
Hi everyone:
P0480 and P0526.
Thanks!
Hi
Did you ever get this sorted
boston4
07-22-2020 09:31 AM
arains44
06-19-2020 09:48 AM
boston4
04-15-2020 01:46 PM
MyRoversNameIsCarl
02-08-2016 09:03 PM
bbaileyii
09-27-2013 09:08 AM
Quick Reply: P0480 and P0526 codes thrown after water pump replacement - input appreciated!
