P1810-00 error
Old Feb 15, 2024 | 07:52 AM
Rustybolts57's Avatar
Default P1810-00 error
I get this code coming up after a few consecutive drives done in a short period. Hours later all will be well. Any thoughts anyone? I do not own a Gap tool.
Thanks
Old Feb 17, 2024 | 06:14 PM
Update: I'm thinking that the errors are caused by low voltage while cranking. I have been monitoring the voltage, sometimes while cranking it would dip below 9 volts, that aligned with the times I would get the error. I'm not sure why it would only drop that far sometimes but below 9 volts is enough to shut the computer down briefly and cause errors. I'm going to replace the battery this week and see how that goes. Age isn't on the batteries side at this point. If that fails I will have to check the starter current draw.
KamboMD
Nov 6, 2025 11:01 AM
zsliu
Mar 24, 2023 04:50 PM
Lr34grdkdz
Nov 1, 2022 04:14 PM
Philip Chan
Jun 21, 2019 11:23 PM
