Passenger-Side Heater and A/C Knob Temp Lo and 60 only
Old Oct 21, 2021 | 11:54 AM
ljdiscovery's Avatar
Default Passenger-Side Heater and A/C **** Temp Lo and 60 only
The fun just doesn't stop with these Land Rover products......I noticed that the passenger-side temp **** for the heat and a/c will not adjust. It is either at Lo is the driver's side is on low or 60 if the driver's side is on any other temperature other than Hi and then the passenger side also auto switches to Hi. Oddly, the actual air that comes out of the vents is seemingly the same as the driver's side. I have disconnected the battery with no impact on the "temp" shown. Has anyone dealt with this issue before? Can it be reset or fixed or is it time for a replacement hvac control panel? Thanks, Phil
Driver's Side Passenger Side
Lo Lo
60 60
61-84 60
Hi Hi
2010 Stornoway Grey Range Rover Sport HSE 132,000 miles, bit of a problem child, but it is getting there
2010 Santorini Black Range Rover Sport HSE 96,000 miles, pretty close to fully dialed in
Jonathan Valverde
Nov 26, 2018 08:42 PM
socalrover
Mar 23, 2014 08:40 PM
rrbc
Nov 13, 2009 04:59 PM
petercanston
Aug 6, 2008 06:07 PM
