Restricted Performance - vehicle won't accelerate
Old Apr 27, 2020 | 07:35 PM
wesareed's Avatar
3rd Gear
Angry Restricted Performance - vehicle won't accelerate
Hey folks,
I've got a 2011 LR4 and for the most part, it operates just fine. But every so often both the yellow and red warning lights turn on, the car buckles a little and then it won't accelerate past 10mph. The messages in the display rotate as follows: "Restricted Performance", "HDC Not Available System Fault", "Stability Control Not Available Drive Carefully", and "Emergency Brake Assist Not Available".
I've taken it to a specialist and the dealership and they can't figure it out. Had the ECM(?) replaced as well. Desperately looking for some clues as to what's going on.
Old Sep 21, 2023 | 12:44 AM
tifkay024's Avatar
Did you ever get the problem fixed I'm having the same issue
Old Oct 2, 2023 | 11:54 AM
rique8405's Avatar
4wd High
Having the same issue. Still haven't been able to find the source of the issue. Indy shop told me it could be the throttle body or the ecu. Battery was replaced, throttle body was cleaned, map and maf were cleaned. Only happens intermittently but has been getting worse.
Old Oct 2, 2023 | 11:56 AM
rique8405's Avatar
4wd High
Started giving throttle position actuator code and camshaft position sensor code as well.
Old Oct 4, 2023 | 05:55 AM
guy's Avatar
guy
Perhaps the battery was replaced…. but when there are this many unrelated systems misbehaving, it is surely an electrical issue.
Humour us. With the vehicle not running and sitting all night long not on a charger, report the battery voltage.
Old Oct 6, 2023 | 09:03 AM
steevo67's Avatar
Without codes, all you'll get here is wild speculation
Old Oct 8, 2023 | 06:15 AM
guy's Avatar
guy
True enough. When you read the workshop manual you will discover that the comment above is the first pinpoint test… always.
Old Oct 30, 2023 | 08:42 AM
rique8405's Avatar
4wd High
So I went and got a new battery and replaced the camshaft position sensor. I have not had a single problem since then. Car has been running fine.
DonRW2007
Mar 24, 2020 07:53 AM
Friday Night Disco
May 26, 2019 08:54 PM
y2motoskier
Apr 28, 2012 02:45 PM
y2motoskier
Apr 28, 2012 02:31 PM
