Roof Rack Length
Yes, and no.
If you mean a rail that would mount on the roof that would extend forward up around the sunroof, then look at part # VPLAR0075 which will mount on your roof and allow your cross bars to move farther forward. Sounds like you already have the short rail mounts that do not extend forward past the sunroof (part# LR055254) if so:
Simply remove the 6 plastic caps, the 6 torx bolts and remove the rail you have now, and then install the new rail with the 8 mounting bolts.
Easy Peasy
Hope this helps
Jeff
Easy Peasy
Hope this helps
Jeff
tyler0430
12-27-2009 10:58 PM
Disco Fuego
10-20-2009 05:28 PM
britishdiscovery
07-01-2008 08:27 PM
dinandan
07-04-2006 10:43 AM
dinandan
06-22-2006 07:22 PM
