Spare electrical plug
Old Jun 27, 2021 | 07:03 PM
jlazyr@gmail.com's Avatar
7th Gear
Default Spare electrical plug
There is a plastic plug on the right hand side of the dash in our 2013 LR4 HSE. When the door is closed it is covered. I pulled the plug out of the hole and discovered that it was also the holder for an extra electrical plug that is green. I’m assuming it is for some accessory that our vehicle doesn’t have. Can anyone tell me what it is for?
Old Jun 27, 2021 | 09:07 PM
Stu Barnes's Avatar
Do you have a pic of the plugs that you’re referring to. It helps a lot
Old Jun 27, 2021 | 10:11 PM
7th Gear
Plug fits in slot by my index finger
Old Jun 27, 2021 | 10:32 PM
Stu Barnes's Avatar
I have the same, I'll check in the electrical documentation that I have and get back to you.
Gives me something to think about on the school run tomorrow
Stuart.
Old Jun 27, 2021 | 10:37 PM
7th Gear
Thank you
Old Jun 28, 2021 | 04:14 PM
7th Gear
Default Possible answer
I lucked out and found a diagram that showed that something in the same area as that plug. It was marked as 14b377. I did several searches for that number and got nowhere. I found a drawing that was clear enough so that I could see it was some kind of two place switch, like On and Off.
I also saw some diagrams that showed an airbag on off switch. I did a search for LR4 airbag switch location and found a video that showed such a switch in the same place as my mystery plug. That must be what it is for.
Betty4banger
Nov 30, 2018 01:01 PM
Toran
Apr 17, 2016 06:48 PM
DAMINK
Aug 18, 2015 04:09 PM
DeepBlueWater
Sep 27, 2011 07:06 AM
DeepBlueWater
Jun 21, 2010 10:11 PM
