Sunroof doesn't work
Old Mar 1, 2022 | 09:50 AM
Crisp's Avatar
Default Sunroof doesn't work
Nothing happens when I press the sunroof button. There is no relay clicking or any movement. Fuse 47 is OK.
Any connector that usually fails? Where is the wiring routed?
Thanks!
Old Mar 1, 2022 | 10:30 AM
DakotaTravler's Avatar
"Press the front of the sunroof switch and hold for 20 seconds. After 20 seconds, the sunroof will begin to move. Keep the front of the switch pressed until the fully open/close cycle has completed. Once the sunroof has stopped moving, release the switch."
In my experience, its a long 20 seconds.
Old Mar 1, 2022 | 10:37 AM
Crisp's Avatar
I did try that procedure but without luck. Both with engine started and only ignition turned on. Maybe I need to try again
Old Mar 1, 2022 | 10:39 AM
Think the vehicle needs to be running. But must be in park, which I assume you were. Like I said, its a long 20 seconds so hold it for up to 40 just to be sure.
FastEddy
Oct 12, 2021 01:35 PM
Luckyjayb
May 30, 2017 10:04 AM
Hurricane Moon
May 1, 2012 06:55 PM
iownme
May 7, 2011 07:10 AM
And4848
Dec 10, 2008 02:40 PM
