Suspension Fault - Cant Figure it out! Need Help!
I have a 2012 LR4 and here is the chronology of events
Fault says Normal Height Available only
- Fault Code is C1A34-01 (AF) Rear Right Corner Valve - General Failure Information - General Electrical Failure
I occasionally get an
C1A36-01 (2E) Exahuast Valve - General electrical Failure. Not sure if these are related.
Car wont go up or down, or at least it starts and immediately gives the fault message.
Things to note:
I'm running an Arnot Compressor
I've replaced the rear right valve block (didnt fix the problem)
Here's another factor. I've tried a valve test through GAP IID on each of the four corners of the car and the rear right does not go up or down. the other 3 wheels have pretty full range of motion. The rear right is happy to sit at normal height but thats pretty much it unless I deflate the reservoir. I've done a cursory glance at the wiring and everything seems to be as it should be.
Cant quite seem to figure this one out. Maybe the Arnott compressor isnt a good fit. Not sure...
Any thoughts or experience shares are appreciated.
Thanks,
Larry
Things to note:
Thanks,
Larry
