Temp sensors are very different
Old May 7, 2023 | 07:17 PM
keninnc's Avatar
Yes I agree with you, I believe the ECU uses the temp sensor from the rear of the engine to open up the thermostat
Old May 7, 2023 | 07:30 PM
jahummer's Avatar
Originally Posted by jlglr4
I don’t believe this wild fluctuation should be happening. Sounds like either a bad temp sensor, air in the radiator making its way to the temp sensor, or a wiring problem with the temp sensor.
However, the temp sensor near the T-stat does not control the t-stat (to my understanding). This is the cold side t-stat that monitors the temp of the coolant coming out of the radiator before it joins the loop through the block. This t-stat should always be significantly cooler than the hot side t-stat, which is at the back of the engine measuring the temp of the coolant leaving the block.
Right then, as you know from the other thread, I've got an issue with the pressure not being relieved from the circuit even when cold for days. I've vacuumed multiple times, bled coolant with no air release multiple times, lifted the reservoir which did nothing and have raised the front of the truck 45 degrees just to see if anything came out. Heat blows hot.
Is there any way to test the t-stat? Hate to go through the effort of fitting a new one and accomplishing nothing.
Old May 7, 2023 | 08:19 PM
keninnc's Avatar
The pressure should be released when the engine is cold, like sitting there for 12-16 hours cold. That is with any car so something is going on.
Only thing I can think of is unplugging the electrical connector to the thermostat housing and checking it with a multi-meter with the ohms setting. I don't know what the correct reading would be.
Old May 7, 2023 | 08:43 PM
jahummer's Avatar
Agreed, it's how it used to be and how my other vehicles operate. Quite confident the circuit remaining pressurized's not normal, the question's why? If it's air trapped somewhere, all options for removing it have been exhausted as far as I know unless it's an issue with the front t-stat stuck closed. When I fitted the new radiator 2 months ago, I could hear the t-stat clicking when I was filling and running the engine.
Also trying to understand the temp differential I'm observing between front and rear and if it means anything with regards to this or something else.
Old May 8, 2023 | 09:10 AM
jahummer's Avatar
Your thermostat may be not opening fully if temp sensor 2 it is topping out at 165.
Due to the back order, I elected to put in the thermostat housing from the V8 LR4. This has the same hose connections but has a normal style thermostat (not electric) inside to control the bi-pass and open the thermostat. The thermostat housing for the V6 supercharged 3.0 has an electronic thermostat. Per the workshop manual this is so the ECU can manipulate the bi-pass and thermostat flows without having to wait for the water to heat up to "control the flow and pressure, to protect the engine components." The bi-pass starts fully open on the V8 thermostat housing so the flow is there and the thermostat is 190 degrees when it begins to open vs. "208-2015" to begin to open and "226" fully open.
I took the old electrical connector off the old thermostat housing and made a blank out of it and wrapped it with gorilla tape and then zip tied it secure. No codes, I think it was just an electrical current with no feedback to the ECU.
I like having a lower temp thermostat. I'm coming from the D2 world where Land Rover intentionally ran the engines hotter to comply with emission standards. The negative part is hotter engines over time don't last as long. I believe the same is being done with a lot of newer engines, hotter for emission requirements at the detriment of the life of the engine. Running in in the 190's.
Today it's been a bit different. Ambient temp 30 degrees lower than yesterday, for 100 miles of driving T-stat temp has been at 80-90 F and ECT at 215-220F. Checked temp of T-stat housing, top is 184 F and bottom is 120 F. If the t-stat doesn't fully open until 226F, then why would it ever open if temps never get that high?
Now that you've fitted a new t-stat, what is the differential between the sensors on yours?
A tech I know says there must be air trapped in the t-stat which's causing all of these issues, but no idea how to get the air out since there's no bleeder on the t-stat.
Old May 8, 2023 | 01:05 PM
keninnc's Avatar
My LR4 is a re-build so I'm just getting it going. I don't have a licence plate on it yet so I've only driven it around the neighborhood. But it is in the mid to upper 190's. Sitting at idle 203.
After everything gets up to temp especially at idle the temps match or are very close.
I don't think you have air in your thermostat, it would have been pushed out by the flow by now. I think your thermostat is just not opening all the way or the bi-pass valve is not closing so not enough flow is going through the radiator to bring up the temps of sensor #2 (just below the thermostat housing).
Old May 8, 2023 | 01:29 PM
jahummer's Avatar
The upper radiator hose gets to 180+ surface temp and like the rest of the hoses, rock hard, does that affect any of the diagnosis here?
Old May 8, 2023 | 02:04 PM
keninnc's Avatar
Better place to test that temp is remove the small skid plat. You may have to also remove the plastic guard that is on the passer side. You will be able to feel the large hose coming to of the bottom of the radiator. If it is 80-90 it will not be warm. That is the issue I had, the bottom radiator hose was never warm until I replaced the thermostat housing.
ebay has knock off versions that are not expensive but I'm weary on using one since Lucky 8, Atlantic British or British Parts Utah only stock the Land Rover version. My local dealer said they are on back order until the third week of June.
Old May 10, 2023 | 09:26 PM
jahummer's Avatar
So this's what I'm noticing for the past few days. When the ECT is 215-220 F, the t-stat temps is 80-120 F but as the ECT drops, the t-stat temp increases. Yesterday, ECT was 180-190 F and t-stat temp was as high as 170 F. Today however, ECT was 180-190 F and t-stat temp went as high as 180 F. Seems the temp differential gets smaller when idling for extended periods and increases when driving, meaning as ECT increases, t-stat temp decreases. Still no change with the hoses not deflating.
Old May 11, 2023 | 06:08 PM
keninnc's Avatar
I know you said the overflow tank cap is new but that is the only thing I can think of that is not releasing the pressure
