Thread watched 2016 LR4 Coolant Leak 50k miles (tstat, water pump, front pipe)
Old Nov 26, 2025 | 03:10 PM
ttforcefed's Avatar
Default Thread watched 2016 LR4 Coolant Leak 50k miles (tstat, water pump, front pipe)
OK a buddy's 2016 was pressure tested and is leaking coolant from the thermostat, water pump and front pipes.
I advised him to do pcv valve and vacuum pump while they're at it, and to use metal pipes from Lucky8 where available.
Any other suggestions while they're doing this?
The rear y pipe has already been replaced.
Old Nov 26, 2025 | 06:14 PM
cybercop's Avatar
Going thru the same thing with my 2013 LR4 v8, not the 6cyl
After over 190K miles, just now needing to do it.
Depending on your miles, I would suggest anything you have to go past after taking the intake manifold off replace it. Most of the labor is in taking off the intake manifold.
I am going to get the 5.0l v8 coolant upgrade kit from Lucky8 and put in a LR OEM front cross pipe. Lucky8's kit for the non SC 5.0L v8 does not have a aluminum front cross pipe.
I think their v6 upgrade kit includes both front and rear cross pipes
Pay Once, cry Once.
Old Nov 26, 2025 | 06:18 PM
ttforcefed's Avatar
Which part number are you going to use for the front?
Old Nov 27, 2025 | 06:51 AM
cybercop's Avatar
LR018275GEN
Remember, this is for a 2013 LR3 5.0L v8. The 2016 has a supercharged 6 cyl
SRob
LR4
Jul 27, 2025 11:06 PM
travism1970
Jul 22, 2024 07:36 PM
themadrussian
LR4
Mar 22, 2024 10:54 AM
Centuri89
LR4
Aug 7, 2023 07:06 AM
LR4DK
LR4
Sep 20, 2021 11:59 PM
