Used 2011 lr4
#31
#32
R1 Concepts eLINE Series; Black Edition Cross-Drilled Brake Rotors & Semi Metallic Brake Pads - Rear Kit @ 92,758mi. I reused the Passenger Side Sensor & Brake Pad Hardware as these were not included in my eBay purchased kit. Cleaned & Inspected the Electronic Parking Brake mechanism and Pads which perhaps are OEM?
Brake Pads & Rotors $153.97
Sea Foam Motor Treatment (20oz) @ $9.84 (AutoZone Rewards)
Passenger Side
Drivers Side
Passenger Side
Drivers Side
#34
Experienced my first breakdown last Friday @SC Fuels
09/11/2020
I initially replaced the Battery but it turned out to be the Alternator. I also addressed the Oil leak from the Brake Vacuum Pump @ 94,715mi
LR023421G: Denso DAN1103 @ $191.63
(LR012685) Brake Vacuum Pump Gasket @ $17.93 & Viton O-ring @ $9.84
Added two (2) qts of Royal Purple 5W-20 @ $21.88 & some Lucas Synthetic Oil Stabilizer @ $19.70
09/11/2020
#37
I’ve had a small but persistent leak from the Oil Filter Cap so I replaced it along with the Oil Filter @ 95,292mi.
Oil Filter Wrench $0.00 (Courtesy of Amazon)
Oil Filter Cap $33.42 (LR019477)
Oil Filter $9.86 (LR011279)
Total $43.28
Total $43.28
Last edited by Luis Fernando Gutierrez; 03-21-2021 at 06:32 AM. Reason: Added Total
