Used 2011 lr4
Old Jul 1, 2020 | 07:06 PM
  #31
Luis Fernando Gutierrez's Avatar
I replaced the Cabin Air Filter today @ 92,557mi and was a little disappointed to see it was not only due for replacement but also that it was a cheap aftermarket non-charcoal type.
Cabin Air Filter $11.62
Old Jul 10, 2020 | 06:30 PM
  #32
R1 Concepts eLINE Series; Black Edition Cross-Drilled Brake Rotors & Semi Metallic Brake Pads - Rear Kit @ 92,758mi. I reused the Passenger Side Sensor & Brake Pad Hardware as these were not included in my eBay purchased kit. Cleaned & Inspected the Electronic Parking Brake mechanism and Pads which perhaps are OEM?
Brake Pads & Rotors $153.97
Sea Foam Motor Treatment (20oz) @ $9.84 (AutoZone Rewards)
Passenger Side
Drivers Side
Old Aug 23, 2020 | 10:13 PM
  #33
PCV Valves @ 94,034mi
LR133579 X2@ $54.75
Last edited by Luis Fernando Gutierrez; Feb 25, 2021 at 03:09 PM. Reason: Added part #
Old Sep 20, 2020 | 09:40 PM
  #34
Experienced my first breakdown last Friday @SC Fuels
09/11/2020
I initially replaced the Battery but it turned out to be the Alternator. I also addressed the Oil leak from the Brake Vacuum Pump @ 94,715mi
LR023421G: Denso DAN1103 @ $191.63
(LR012685) Brake Vacuum Pump Gasket @ $17.93 & Viton O-ring @ $9.84
Added two (2) qts of Royal Purple 5W-20 @ $21.88 & some Lucas Synthetic Oil Stabilizer @ $19.70
Old Sep 28, 2020 | 10:30 PM
  #35
I replaced the Air Filters today @ 95,010 and was disappointed to see they were cheap aftermarket FRAM filters.
LR011593: MANN C35126 @ $47.85
Old Sep 29, 2020 | 01:16 PM
  #36
2021 Registration @ $256.00 + $5.38 (Credit Card Service Fee)
Old Oct 5, 2020 | 04:19 PM
  #37
I’ve had a small but persistent leak from the Oil Filter Cap so I replaced it along with the Oil Filter @ 95,292mi.
Oil Filter Wrench $0.00 (Courtesy of Amazon)
Oil Filter Cap $33.42 (LR019477)
Oil Filter $9.86 (LR011279)
Total $43.28
Last edited by Luis Fernando Gutierrez; Mar 21, 2021 at 06:32 AM. Reason: Added Total
Old Oct 25, 2020 | 04:17 PM
  #38
Coolant topped-off @ 95,885mi with
Red Line Water Wetter “Super Coolant” (80204) @ $10.94
Old Nov 2, 2020 | 08:30 PM
  #39
@ 96,116mi I added another 300ml of Friction Modifier (CERATEC by LiqiMoly) $17.52
Old Nov 7, 2020 | 06:54 PM
  #40
$20 Tire Rotation @ Rolling Tires & Wheels in Bellflower (96,325mi)
