Used 2011 lr4
Old Dec 11, 2020 | 09:35 AM
  #41
Luis Fernando Gutierrez's Avatar
Tire Patch $10 @ Rolling Tires & Wheels in Bellflower.
I’m also experiencing a slight vibration @ cruising speeds, might be time for a rebalance...
Old Jan 2, 2021 | 07:24 PM
  #42
@ Alondra Auto Wash in Paramount. The best Self-Service Auto Wash in the area.
01/02/2021
Old Jan 24, 2021 | 06:12 AM
  #43
I reused the Drain & Fill Plugs. Transfer Case Serviced @ 98,265mi.
Royal Purple Synchromax was $35 at Team C Performance & $13.13 for a Fluid Pump from the local AutoZone.
Old Jan 26, 2021 | 04:10 PM
  #44
I flushed the Power Steering Fluid in two intervals and added some more Sea Foam Motor Treatment.
Prestone European Fluid 12oz X2 @ $10.95 (AutoZone Rewards)
Sea Foam 20oz @ $9.30 (AutoZone Rewards)
Old Feb 16, 2021 | 07:43 PM
  #45
Parts & Labor @Land Rover Riverside
LR041462 (Windshield) $357.87
LR096164 (Cowl Grille) $79.64
LR046853 (Pillar Molding) $80.04
LR046851 (Pillar Molding) $80.04
LR038120 (Wiper Arm) $52.95
LR038124 (Wiper Arm) $53.51
DKG500011PMD (Arm Caps) $8.40
(Wiper Arm Nuts) $0.00 @ Land Rover Riverside
Photos to follow,
Old Feb 18, 2021 | 04:21 PM
  #46
adamsanta85's Avatar
Originally Posted by Luis Fernando Gutierrez
Last attempt was futile but I have now Upgraded the Low Beam Incandescent Bulbs to LED’s
BEAMTECH Model: S1-H11 @ $32.84
I thought LR4 were H7? Any issues with flickering or anything?
I've been rocking Beamtech's in my wife's X1 for 3 years now, no issues at all.
I am picking up a 2013 LR4 in a few days and need to convert the Low beams to LED immediately.
Old Feb 21, 2021 | 07:05 AM
  #47
Yeah, I feel you... I’m fortunate to have the 2010-2013 Land Rover LR4 “Fairy Lights” but the Halogen Headlamps definitely need be upgraded. Next up, LED Fog Lights. Those Morimoto XB’s would be nice!
Old Feb 25, 2021 | 03:25 PM
  #48
I reused the Drain & Fill Plugs. Front Differential serviced @ 99,0069mi
1qt of Royal Purple MAXGEAR 75W-90 was $17.66 @ Team C Performance
Old Mar 13, 2021 | 09:41 AM
  #49
LED Bulbs to replace the Incandescent Back-Up/Reverse Bulbs. I’m not really satisfied with these particular LED’s but that’s probably reflective of their price I guess.
1156 Type Generic LED’s @ $8.76
Old Mar 20, 2021 | 11:47 PM
  #50
100K Mile Oil Change - The previous Oil Change was @ 92K (Post #29). I drained & filled a couple quarts @ 94K for the Brake Vacuum Pump Gasket (Post #34) & replaced the Oil Filter @ 95K (Post #37) for the Oil Filter Cap Replacement.
Engine Flush $0.00 (Courtesy of FCP Euro)
Engine Oil $79.02 (0W20 Special Tec LR - Liqui Moly LM20408)
Engine Oil Filter $9.86 (LR011279)
Friction Modifier $32.84
Total $121.72
I only used 500ml of Engine Flush for this Oil Change vs the 1000ml I previously used but kept the Friction Modifier @ 600ml. Also, previously added 300ml of Friction Modifier (Post #39) @ 96K.
💯 Thousand Mile Oil Change
