Where can I buy OEM lift rods?
Old Jul 26, 2023 | 02:55 PM
Regulator's Avatar
3rd Gear
Question Where can I buy OEM lift rods?
I have Johnson Rods installed on my Disco' 4 at the moment. I used to swap them out when driving at my farm or the like. The motor exploded a couple of years ago while the lift rods were installed. Over the course of the two years, two shops and three motors it took to get it back on the road, the OEM lift rods were discarded from trunk. The truck sat far too high, beyond extended height when the new motor was installed. A resetting of the software lowered it a little, but not as far as it should be and the rear is far higher than the front--the thing is jacked up and unsafe, and needs an alignment.
Does anyone know where I can buy some factory height rods without the entire assembly? Used ones or aftermarket would be just fine.
Thanks for your help.
Old Jul 28, 2023 | 02:24 AM
guy's Avatar
guy
Other than just auto-parts.com? No.
Old Jul 28, 2023 | 07:17 AM
jeffh's Avatar
I would give atlalntic British a call see f they have a set. It snot something you typically see as line item pieces for sale.
Old Jul 28, 2023 | 10:50 AM
guy's Avatar
guy
"just the arms"? Doesn't the the LR Parts catalogue only shows the complete assembly?
Old Jul 30, 2023 | 05:01 PM
kajtzu's Avatar
The rods come as part of the sensors…. There isn’t a separate part number for each, unfortunately.
Old Jul 30, 2023 | 10:16 PM
sdtimb's Avatar
I'm pretty sure there are quite a few people who have upgraded to lift rods that have a pair they'd give you for shipping costs. I'd post something in the classifieds. You'll probably have better luck on Land Rover World (.org)...their LR3/4 community is way more active.
Old Aug 1, 2023 | 08:54 AM
Regulator's Avatar
3rd Gear
Thanks for the replies.
Yes, LR only sells the whole assemblies. Not the rods or "arms" alone.
I thought I would get a quick hit from the classified ad I posted at the same time as this. No such luck.
I will try crossposting on LRW.
ORDPA
Jun 21, 2023 02:53 AM
brenorman
Dec 30, 2022 10:03 AM
SmokinV10
Sep 6, 2022 07:20 PM
LR disco 5
Jul 10, 2022 04:07 PM
Tratcliffe
Dec 24, 2015 01:26 AM
