04 D2- Turner engine already installed
2004 Land Rover Discovery
  • 2004 Land Rover Discovery - 04 D2- Turner engine already installed - Used - VIN salty19444a830894 - 121,000 Miles - 8 cyl - 4WD - Automatic - SUV - Gray - Windsor, CA 95492, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    $11,000
    • OBO
  • Location Windsor, CA, 95492, USA
  • Condition Used
  • VIN salty19444a830894
  • Mileage 121,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Gray
Reposted from "Retired" marketplace
Bought in Los Angeles in 2009 with ~40k on the clock, currently has 121XXX.
In July of 2017 The engine was diagnosed with a cracked block with ~99K miles. Rebuilt longblock from Turners (UK) installed along with all new hoses and sensors. Have driven it for over two years and almost 22k miles. These Turner engines are all I had hoped for. Just passed CA emissions. Doesn’t use coolant or oil. But, there is a little oil seepage from valve covers. Just to remind you it’s a Land Rover :-) No need to add oil between 3k Rotella 15/40 oil changes.
Bonatti Grey
Black leather
Dual sunroof model
Never taken to salty roads in the winter. Only real off roading was on half day Land Rover Marin sponsored trip on the Sonoma Coast.
Rust free always CA car- no snow trips to Tahoe.
Clean car fax, @ 99,500 miles -installed rebuilt turner long lock, all new engine accessories (motor mounts, front cover/oil pump, cam sensor, crank position sensor, tensioner, etc) 4900 British pounds for the block and oil pump alone (With sensors, etc I spent about $9k)
Rewrapped wiring harness, new coolant reservoir, new cowl, water pump, water temp gauge installed
Nice rumble from resonator delete
Dash started to warp, so installed hold-down kit
Pads and rotors @ 84k
Pirelli scorpions @ 70k
Toms woods front driveshaft
New radiator in 2017
Always used Rotella 15-40 since break in-180 degree thermostat at engine swap, gauge inside
New coil packs, wires, plugs
New park brake and 4wd shifter leather
Stainless brake lines
Pioneer head unit with apple/ google play with backup camera
Recent brand new tail light housings
There’s work to be done:
Headliner cloth starting to droop
Rear windows worked but do not right now
Drivers electronic seat adjustment not working at the moment
Wheel arches need refresh
Sunroofs don’t work when hot outside, so unplugged
Rear pass door seal has some wind noise at hwy speeds
Oil seeping at valve covers, no drips
Intermittent three amigos, haven’t had time to perform option B repair
Roof started showing signs of clear coat failure, so had a local auto wrap shop cover the roof in 3m white vinyl to cut down on summer heat and protect the paint, plus looks badass. Comes with a few backup parts from engine swap and a set of all weather mats, do not have cargo area. The drivers mat does have a crack at drivers heel though.
When engine first installed, blackstone showed high levels of lead. The levels have continually declined at every oil change. September oil change report attached.
I would drive this anywhere in North America without worry. Its in amazing shape for a 16 year old car, but has wear that you would expect.
I believe that when selling vehicles, that exterior shots should be after detailing and that engine compartment shots and under carriage shots should be as is.
$11K obo
Link to old ad:
https://landroverforums.com/forum/re...talled-103559/
Old Feb 11, 2021 | 12:25 PM
redwhitekat's Avatar
i dont see the 180 inline mod ??
Old Feb 11, 2021 | 03:32 PM
Ducatiryan's Avatar
I see the issue. I installed an inline temp gauge and a 180 degree thermostat. I did not do the inline thermostat mod. Will edit orig post.
Old Feb 12, 2021 | 07:01 AM
oh ok thanks
Old Mar 10, 2021 | 03:50 PM
Ducatiryan's Avatar
Price drop- $11k obo
Old Apr 9, 2021 | 04:34 PM
kjogel's Avatar
4wd High
PM Sent
