Lr3 for sale
2005 Land Rover LR3
  • 2005 Land Rover LR3 - Lr3 for sale - Used - VIN SALAA25415A315568 - 144,340 Miles - 8 cyl - 4WD - Automatic - SUV - Red - Dresden, TN 38225, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $4,500
    • OBO
  • Location Dresden, TN, 38225, USA
  • Condition Used
  • VIN SALAA25415A315568
  • Mileage 144,340
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Red
Have my 2005 LR3 SE for sale. This a one owner LR3 purchased new from Land Rover Nashville. Most service performed on vehicle was performed at Nashville dealership. Have service history and inspection records including oil changes. Currently air strut system leaks air over time but works. New front air struts installed at 139,000 miles. Dif and transfer case fluids changed with OEM oil at 121,000 miles. Vehicle has a water leak that appears to be coming from corner of sunroof however Dealership tech replaced front drain hoses at 139,000 miles. No fault dash lights on. This LR3 has never been in an accident, paint is still good and has no rust issues. Vehicle comes with the auto locking rear Dif and full size spare. This is a good vehicle, runs and drives good with no serious off road use or mud’n. Tires are (5) size 265/60/18 BFG KO’s with approx. 9/32nds tread remaining. Vehicle has not been modded in anyway other than small increase from stock tire size. Questions welcomed.
Old Mar 29, 2023 | 06:32 PM
Ericlockheed's Avatar
are you a dealer?
Old Mar 29, 2023 | 09:09 PM
TNLR305's Avatar
Good question. No. I am the original buyer and the one owner alluded to in the LR3 description.
Old Mar 30, 2023 | 03:23 PM
ScaredyCats's Avatar
Currently air strut system leaks air over time but works. New front air struts installed at 139,000 miles...so is it the rear struts that are leaking?
And water leaks since replacing front drain hoses on sunroof?
Old Mar 30, 2023 | 05:34 PM
TNLR305's Avatar
Air system leak has not been diagnosed since installation of new front struts. Rears are the original struts. 2nd question Yes. I think there is one leak. It shows up in front driver side corner just below sun visor attachment point. Odd that the driver's side drain works but passenger side does not. Both worked after new drain install. New windshield installed 7/2021 and it was determined that there was no leak around the old windshield.
Old Mar 31, 2023 | 08:47 AM
Boostle's Avatar
Private messaged
Old Apr 1, 2023 | 11:39 AM
Nugard's Avatar
7th Gear
Hi Eric,
If the LR3 is still available I am interested.
Old Apr 9, 2023 | 09:46 PM
TNLR305's Avatar
Here are vehicle maintenance records for anyone who might be interested in the vehicle. I have had one person ask for this information:
Vehicle was purchased from Land Rover Nashville with 7,852 miles on odometer. It was used in their loaner program.
12/6/05 - 8141mi Warranty work on fuel tank assy and coolant jug
6/14/06 - 12896mi Service
12/21/06 - 17343mi Service
6/27/07 - 21274mi Service & New compressor
4/16/08 - 30049mi Service & New steering wheel, New rear axle assy
12/22/08 - 38220mi Service
7/31/09 - 42980mi New Compressor
7/16/10 - 53166mi Service and sunroof drain repair
2/24/12 - 69655mi Service & brake service, new lower control arms rear
1/02/14 - 87962mi Service
11/28/14 - 9654mi Service
11/26/15 - 104062mi 100500 mile Service + fluids & New brake pads rear
6/20/16 - 107931mi Service and Front control arms and alignment
1/9/2018 - 121159mi New difs and transfer case OEM fluid change by local shop
2/22/19 - Parking sensor speaker replaced
12/18/19 - 128337mi Brake inspection and replaced front pads and rotors. Bleed brake lines. Replace thermostat
4/30/21 - 139172mi New front air struts, alignment and new front sunroof drains
7/15/21 - New heated windshield + a-pillar trim and new windshield cowling
9/16/22 - 143076mi Alignment by tire shop
3/29/23 - New battery
Unless noted all work listed above except for 12/18/19 and 7/15/21 was performed at LR Nashville. I have done a lot of oil changes myself using LR or K&N filters in addition to the ones LR performed. LR performed oil changes for entries that have service listed. In total the oil has been changed 32 times over the lifespan of owning the LR3. I might have missed some work but this should cover most of it.
Old Apr 25, 2023 | 12:13 AM
mdisalvo's Avatar
sent you a PM
