1998 disco lift,
Old May 13, 2009 | 01:36 AM
skatelove303's Avatar
Default 1998 disco lift,
Hey im looking to lift my 1998 Discovery, three maybe four inches. But im having trouble finding a kit. I want to use it for off roading, and everyday driver.
Plus can anyone give me a heads up on where the Idle air control valve is located? My LR has been dying in idle very rarely and i think that the IAC valve is the problem.
Old May 13, 2009 | 10:34 AM
Are you aware that a 4" lift on a D1 will cost you big time, new drive shafts, shocks, Brake lines and a number of other suspension parts?
Go to RTE and do some reading.
How big a tire are you looking to go to, what about your diffs.
Old May 13, 2009 | 11:50 AM
I dont want to have to do all that, So im guessing a two inch lift wouldnt require all those other mod's right?
Anyone know where i can find a 2" lift for my 1998 land rover discovery?
So im thinking dual exhuast also, Am i going to get completely flamed for asking this?
Old May 13, 2009 | 12:03 PM
LANDZUII's Avatar
No just a little tosted,,,
I kidding springs will give you the lift of 2" and then the only thing you could use is brake lines around $100 USD. springs and shocks $600 USD.
On the exhaust its a very tight fit under your Disco and on the Right rear you have the gas filler neck. if you want that V8 sound high flow cat's and a magna-flow muffler with the rest of the exhaust stock give you that low rumble with out the rice/sound.
Old May 13, 2009 | 12:41 PM
So to lift mine it would cost...700 bucks? jeez and for the exhaust im looking for a nice v8 rumble like your saying, then i guess those cat's and muffler will do me right. Thanks guy's before the end of the month il hopefully have my LR Chipped lifted and exhausted.
Old May 13, 2009 | 06:23 PM
For the exhaust, cut off the rear resinator and forget the rest, that is a waste of money.
Where do you live?
RTE make great springs but they are better then 2 months behind.
Old Man Emu is my choice, send me you tele number and we can talk about your options.
Old May 13, 2009 | 07:36 PM
antichrist's Avatar
If you want 4" for tires, you could always do a 2" suspension and 2" body lift. A body lift doesn't require you to make any suspension changes at all, other than maybe extended brake lines.
Old May 14, 2009 | 03:22 PM
LANDZUII's Avatar
Talking
CHIPPED!!!!
Alright another Gear Head Welcome!!!
Old May 14, 2009 | 03:25 PM
LANDZUII's Avatar
What kind of Chip are you going to get?
Old May 15, 2009 | 02:06 AM
Ive been looking at powerchipgroup.com. Unless anyone knows a better chip? thats not much more then 500 bucks.
