2 inch spacer lift help
Old May 17, 2009 | 05:02 PM
NewRoverOwner's Avatar
6th Gear
Default 2 inch spacer lift help
I found the other day a website that offered a 2 inch lift that was spacers and shock relocation mounts but i cant find it again i was going to see if any one knew which site it was and could help me out
Old May 17, 2009 | 08:52 PM
AK Rover's Avatar
Save your money and wait until you can afford new springs before you worry about a lift. Your factory springs are weak and spacers will make your truck more top heavy because of the springs.
Old May 17, 2009 | 09:17 PM
Dexlen's Avatar
Disco's do better with upgraded suspensions like OME or RTE. They are very heavy.
But you did ask for some help, so..
http://toddcosuspensions.com/index.html
Hope that's it
Old May 18, 2009 | 10:29 AM
Cancel that order, it is not a good way to go with a Disco.
Old Jun 3, 2009 | 08:00 PM
KarenCaren's Avatar
Right. Save the money and get your spring upgrade. It will give you more stable ride.
_________________
If you ain't first your last!
Ring and Pinion Sets
Freedom38
Jun 26, 2015 10:37 PM
EnglishBill
Apr 19, 2014 10:03 AM
Frank4
Jun 30, 2012 07:13 PM
Spencerfitch
Feb 2, 2011 10:08 AM
kaczman
Feb 4, 2007 04:22 AM
