3 gauge dashboard cluster installed
Old Aug 19, 2014 | 04:18 PM
aroshan's Avatar
Default 3 gauge dashboard cluster installed
I did not really take any install pictures it’s a mess of wires, but I got everything from glow shift.
52mm gauges, oil pressure, oil temp, water temp, also need and adaptor for the oil filter to read oil temp and pressure. A 32mm coolant water sending unit adaptor. The pod is a $13 generic pod that fits on the dash held in with 2 wall screws with the push through wall spreading wing nut. Everything again was from glow shift, not the greatest quality but I like it just fine.
Just one tip when running wires through the fire wall drill a hole and use a pass through grommet. My old oil pressure unit only lasted 3 years till it sliced through the wire.
Old Aug 19, 2014 | 04:42 PM
MM3846's Avatar
nice. that pod setup is a bit cleaner than mine, i like it.
abran
Apr 23, 2015 02:52 PM
jshivel
Aug 4, 2014 03:23 PM
03discoman
Jan 14, 2010 09:11 AM
03discoman
Dec 22, 2009 03:08 AM
underpsi
Sep 1, 2007 12:51 AM
