armor measurments
Old Jan 8, 2008 | 09:30 PM
Rob82402's Avatar
Default armor measurments
I want to make some skid plates for the engine tranny and transfer case. does anyone have exact measurments i would need to make them?
Old Jan 9, 2008 | 07:52 AM
Default RE: armor measurments
WHY???
Are you aware of the heat issues caused by some skid plates and how incovenent it is to be plated and work on the truck, beside the amount of lost clearance you'll have?
Where do you, and what type of trails do you run, are you lifted?
Old Jan 9, 2008 | 10:26 PM
Rob82402's Avatar
well as far as the heat issue, id prob go with aluminum. i go de md and soon nj trails. i have 3 inch suspenion and 3 body.
btw what kind of lockers are you running?
Old Jan 10, 2008 | 08:15 AM
It doesn't make any difference what the plating is made from, when you restrict the air flow from undernieght the engine she will run hotter. Besides with all that lift you have if you hit something, you should recheck your line on the trail.
As for lockers, I run a rear Detroit with a front True Trac, 4:11's with HD axles.
drzjoint
Aug 13, 2012 09:58 AM
bosshogt
Feb 27, 2011 06:32 PM
LR03NJ
Tires
Apr 14, 2009 02:52 AM
drzjoint
Jan 22, 2009 10:58 AM
dirtdude
Freelander
Aug 26, 2005 11:00 PM
