Best Mod
Old Jan 5, 2012 | 10:54 PM
honda50r's Avatar
Honestly, I believe the best immediate modification one can perform is removing factory running boards and performing bumper mod.
Why no more Land Cruiser?
Old Jan 6, 2012 | 10:42 PM
Stark_zx10's Avatar
There are a world of salvage parts you can pull yourself for less than a Ben Franklin that in some cases are worth adding to your spares shelf - like an alternator, etc.
Another good interior mod is the Ultra Gauge, which lets you (and the programmed alarm point) keep an eagle eye on coolant temp and other items. About $70. Pix submitted by a member with a D2.
Love the look of that gauge! Keeping an eye on the actual numbers can help spot an issue before something expensive breaks!
Old Jan 8, 2012 | 07:15 PM
tweakrover's Avatar
Bumper trim is def a mandatory mod, and free
Old Jan 15, 2012 | 02:44 PM
DONKTACULAR's Avatar
Replacing the front Muffler with a FlowMaster and removing the rear Muffler all together and running straight pipe out the back! Had it done for $110 and it sounds INCREDIBLE!!! =) They even made a mod if you want to have the pipe dump out the driver side lower rear quarter panel!
Old Jan 15, 2012 | 09:57 PM
honda50r's Avatar
I've been dying to do that, but our muffler shop won't do it. He doesn't recommend it.
Old Jan 15, 2012 | 10:01 PM
Here's one gauge that comes with the Rover from day 1....
Old Jan 15, 2012 | 10:11 PM
livetoride's Avatar
I'm going to have to check into this. How is the sound on the freeway?
Old Jan 16, 2012 | 09:32 AM
fishEH's Avatar
Won't do what? Cut the resonator off or pipe it to the drivers side? You can cut the resonator off with a hacksaw or sawzall. Try taking it to an exhaust shop that ISN'T a major chain like Midas is. By me we have about a half dozen independent exhaust shops all called Velasquez or Rodriguez. They'll weld anything, they don't care as long as you have the scratch.
Old Jan 16, 2012 | 09:46 AM
Yeah my guy said the resonator is only there for ommission control(aka State Regs). I had 2.5 pipe bent and run from the cats back to the flowmaster and then str8 back over the rear axle. In my opinion it sounds best on the Freeway at about 60-65mph in High Gear @ about 2,00-2,200rpm.... Its not over-welming at all. He wanted to run a 3.5" outlet to make it louder but I choose just the 2.5" because I didnt want that SUPER LOUD "Yeah it has a HUGE V8 under the hood" noise to it! In my opinion this is the way it should sound from the factory! BTW: I got the idea from this Video land rover discovery exhaust - YouTube
Old Jan 29, 2012 | 05:57 PM
pilsner's Avatar
@tweakrover - how about a "how to" on the grill mod?
