Brake booster & Master
Has anyone swapped in a beefier brake booster and master cyl into a Disco yet? It seems that a lot of the poor braking could be compensated for with more power.
Anyone know what PSI the current system is rated for, and any gotchas when looking at doing this?
Larger calipers means more bore, which means more pressure needed. so either way a master upgrade will help a lot. We used to bore out the masters on race bikes to get the same power at less lever travel but that's a bit different of a game. If you need more power you need more master and a bigger booster.
s10lowrider1994
Oct 22, 2014 08:58 AM
TVO
Mar 15, 2007 12:08 PM
