Brake booster & Master
Old Oct 26, 2007 | 12:32 PM
ajh's Avatar
ajh
Default Brake booster & Master
Has anyone swapped in a beefier brake booster and master cyl into a Disco yet? It seems that a lot of the poor braking could be compensated for with more power.
Anyone know what PSI the current system is rated for, and any gotchas when looking at doing this?
Old Oct 26, 2007 | 12:56 PM
Default RE: Brake booster & Master
I know the 03 had a bigger master cylinder installed along with some new soft ware for the ECU to enhance the brakes.
Old Oct 26, 2007 | 02:15 PM
ajh's Avatar
ajh
Yeah, and they're still not so good. I'm hoping that I can find some off the shelf part that'll just bolt right in. It's one part LR doesn't seem to have done funky.
Old Oct 26, 2007 | 02:54 PM
Biggest improvement will come from larger calipers, you don't have any room for bigger rotors.
Old Oct 26, 2007 | 02:58 PM
ajh's Avatar
ajh
Larger calipers means more bore, which means more pressure needed. so either way a master upgrade will help a lot. We used to bore out the masters on race bikes to get the same power at less lever travel but that's a bit different of a game. If you need more power you need more master and a bigger booster.
elboy0712
Dec 6, 2019 10:43 PM
s10lowrider1994
Oct 22, 2014 08:58 AM
bosshogt
Jun 3, 2013 11:07 AM
coastie
Jan 3, 2013 05:13 PM
TVO
Mar 15, 2007 12:08 PM
