Dual Battery System
Dual Battery System
I want to install a dual battery system. I am thinking about the IBS system or National Luna. The main battery will be in the engine bay with the second battery in the nose cone of my off road trailer. I want to charge the trailer battery while driving. Has anybody else used either of these systems or have another option to consider. I also want to add a fuse box to connect lights,Cb radio,Ham Radio etc. Hoping to hear what others have done .
Your right Ted in regard to running the extra goodies off the 2nd battery, as to not be left with a dead battery to start your engine. I am still thinking about this myself. When DiscoMike said "he did not see the need for a dual setup" and then showed a picture of one I was confused at first. But, I remember him discussing this in the past.
The consideration of a dual setup is to allow the aux. (2nd) battery to charge, but not over charge while you are driving, as well as the primary battery to charge as it would normally. Some of the kits "dual setups" allow the 2nd battery to charge until it is charged, and then cuts it out while monitoring it and cutting it in when the voltage drops below some point, or something like that to prevent overcharging since it may not be used much of the time when you are around town.
DiscoMike's points discussed in the past, IIRC, was that as you can see from his pic, he just basically extended one more battery cable for + and - off the primary battery respective post over to the 2nd battery, for his dual battery setup. The key being that in his setup or "non-setup" that does not require a special aftermarket set of switches and battery monitoring devices is that the batteries are the same type and basically the same age. I cannot recall the logic exactly behind this. Mike can explain it further, but the main idea is they will have the same charging characteristics being the same battery, and being the same age would charge about the same rate. One not always charging before the other or something like that. As you can see, I am still learning this myself.
DiscoMike,
What did you do the stock battery tray to fit is the 2 batteries? Do I recall that you can actually get them in the stock battery tray?
DiscoMike,
Ed - This is exactly what I had planned. Hadn't drawn it out. Thank you. I have been having second thoughts however.....wondering if I really need to run two 4 AWG cables or if I can charge trailer battery through the 7 pin connector. Original thought was that this approach would not provide sufficient charge for a drained trailer battery. Here are my options:
Option 1. Run three batteries 2 in bay 1 in trailer with IBS management system. Winch and Off Road lights and CB off 2nd battery in engine bay. Run 4awg cables to third battery in trailer as you have drawn out.
Option 2. same as above but run smaller wire to 7 pin connector and trickle charge trailer battery when driving. Buy small generator to charge trailer battery when camping more than a couple of days.
Option 3. Same as 2 except replace generator with a solar charger for trailer battery.
What do you think is best option or is there a better option? Note I run a 63 quart frige in the trailer along with lights.
