Header wrap for exhaust manifolds?
Old May 4, 2008 | 11:22 AM
meltdowndave's Avatar
Default Header wrap for exhaust manifolds?
Has anyone tried using aftermarket header wrap to insulate the exhaust manifolds and perhaps increase the life of ignition wires?
http://www.southernrods.com/categori...oduct-827.html
Old May 4, 2008 | 05:21 PM
Default RE: Header wrap for exhaust manifolds?
Just use good wires, Magnecore 8mm, and don't worry about the heat.
Old May 13, 2008 | 10:34 AM
unstable's Avatar
I don't think that header wrap would be as effective on exhaust manifolds as it is on headers. Headers are generally fabricated out of metal tubing. In contrast, exhaust manifolds are made from castings. I think the thicker castings, while constricting exhaust flow to some extent, actually insulate better than the headers by far.
I don't think you'd actually hurt anything by wrapping your exhaust manifolds. It may lower under-hood temperatures a little but I would predict it only having a marginal impact on the engine temperature itself.
In the hot-rod sector, I don't see many people using header-wrap. It has a tendency of trapping water and rotting off of the pipes. Almost more of a pain in the butt than it is worth.
Old May 14, 2008 | 04:22 AM
Bartell's Avatar
ORIGINAL: Disco Mike
Mike's right..though Magnecor 7mm (the black ones) is a good as 8mm for a non racer and easier to install. Exhausting wrapping will simply accelerate exhaust rust. If you want to lower engine bay heat, you could ceramic coat your exhaust manifolds and bay pipes.
James
Old May 16, 2008 | 08:13 AM
Gor to the Magnacor site, the 7mm wires are not as good as the 8mm's.
Old May 23, 2008 | 12:49 PM
Darover's Avatar
Header wrap apparently helps the engine running cooler
Adsan1280
Jul 5, 2011 11:56 AM
Street Wolf
Jun 24, 2011 01:59 AM
sforb
Apr 16, 2009 10:00 AM
Tastang
Nov 10, 2007 09:53 PM
riebs
Headers, Intake, & Exhaust
Aug 23, 2006 07:58 PM
