Help with Hella Driving lights install?
I picked up a couple Hella 1000FF lamps locally and want to mount them to my factory brush bar on the new Disco 2. The only thing I have a are the housings, bulbs, and a couple of wires coming out of the housings (grey & purple). I have a ton of 14g wire laying around in the garage, and I'm looking for what sort of relay and fuse to use? Is there some sort of special relay with a built in fuse I should be looking for or will any rugular old Bosch cube relay work if I add an inline fuse holder?
My other Disco has a set of Hella 500's on the bar that come on with the high beams. Any chance the wiring is there to add the light on the new Disco? Did D2s come pre wired at all? Thanks for the help.
As for the lights, Anyone use them?
roach131313
05-07-2014 05:23 PM
Roflcopter
03-29-2014 07:17 PM
Paul Grant
09-30-2011 12:30 PM
97DISCOIDAHO
09-08-2006 11:56 PM
