ideal supensions for 2006 LR
Old Mar 12, 2015 | 10:33 PM
frankie_500's Avatar
Default ideal supensions for 2006 LR
Hi guys, just wanna get your opinion on suspension lifts. What do most of you use? Thinking of air-to-coil
spring kit. Thanks!
Old Mar 13, 2015 | 06:59 AM
TOM R's Avatar
Leave it alone, spring kits ride like crap, go to the section specific to your vehicle and ask
Helps if you post the vehicle, lr3? Range rover?
Old Mar 15, 2015 | 09:47 PM
It's a 2006 Land Rover LR3 Discovery III. I'd like to know what others here may be using.
Old Mar 16, 2015 | 09:53 AM
Fivespddisco's Avatar
Most people that do the coil conversion are unhappy. The truck sits lower and cannot handle the extra weight of loaded up truck.
Old Mar 16, 2015 | 11:02 AM
justryan's Avatar
i choose the lift spacers on my last 110 , i'm going to do the same on my 90 , the reason is , if you are happy with the way your LR sits as it is now ( pitch angle ), and you change the spring hoping to get the same pitch , but 2 inches higher , it may not be the case always due to additional winch , or hood mounted spare tyre etc etc . with the spacer blocks , you actually remain with the same pitch and you are 2 inches higher ..
Old Mar 17, 2015 | 08:44 PM
Smile
Thank you for bringing up this issue, I do want to maintain the pitch angle. From the looks of it (2 experienced user feed backs, at least), lift spacers might be a better option. I'll look into those, thank you for the input.
Old Mar 18, 2015 | 08:12 AM
justryan's Avatar
No Problem , that what we're here for , just glad to help ....
Bean
Jul 15, 2010 11:13 AM
MagnaflowRep
Headers, Intake, & Exhaust
Sep 2, 2009 12:26 PM
traffictech870
Off Topic
Mar 31, 2005 01:49 PM
landcrzn
Mar 9, 2005 08:21 PM
climehigh
Feb 25, 2005 08:30 PM
