oil leak
on
OK, so where exactly is the leak coming from, from the seal between the axle tube to the swivel or a swivel seal?
Either way, you are probably going to need to order a complete seal kit for both sides as well as bearings if you are over 100,000 and haven't kept the bearing cleaned, repacked and torqued properly.
on
Don't buy a manual before you down load a free copy of a Rave CD, use the link in my signature section.
If you still need help shout. Also Only go to a place like Atlantic British or Rover Connection for the complete seal kit and bearings if needed. Make sure you use the new 1 shot grease packets when refilling the swivels.
thearmlesswonder
07-27-2015 10:16 AM
Phatrowles
01-09-2014 10:36 AM
