Powerchip V8
ORIGINAL: Disco Mike
Just out of curiosity, how many miles on your engine? Also what have you done around your plugs and wires since your rechipping, more voltage will bring up the numbers?
Mike
Mike
Chipped at 93k or 94k have it some where at the house.
Before I chipped it I changed the wires to the Magnecor 8mm and used the oem double copper spark plugs (RN11YCC).
At 82,000 all the O2 sensors got changed (was due to service manual, said it was time.)
Cleaned the intake all the little things to make sure that everything was in top shape.
Just put a Mantec snorkel over the weekend, exhaust is a high flow.
I work on my vehicles to relax, and so when I travel its all go.
The numbers Hp & Tq are what the chip dealer has down.
The mpg will are ok for the way my LR is setup.
In my mind if a chip will get more Hp & Tq then the OEM setup was
half done, for someone like me.
Mike
I am actually going to adjust my MAF and Throttle Pot to see if it leans out first. I just checked over the plugs, wires, cap, and rotor and everything was fine except for the rich plugs. I figure you cant go wrong with adjusting the MAF since it is free. 1.8V here I come!
on
ORIGINAL: dmonares
this will work much better then thrying to tweek the MAF.
Mike
I already tested my MAF and it was putting out 1.87V so I think it is close enough, besides I cannot find any adjustment screw anywhere.
Mike, I just wanted to lean it out since it is running very rich. I'm gonna probably start off with some seafoam and see if cleaning the injectors works. I am really tired of the horrible gas mileage (about 10mpg if we are lucky).
on
ORIGINAL: dmonares
Cleaning out injectors, unless they are just about dead, won't lean you out, may/will run better but it will also allow a better stream of fuel to flow, giving you more gas.
You have to make that engine run better with less throttle pressure, hence better mileage.
Mike
on
Good game plan, how old are your plug wires and are you still running the originail coil? If your wires have over 30,000 miles on them and they are the 7mm size, I would get rid of them going to 8mm Magnacors and a hotter coil.
How about your timing chain, has it been replaced? If not you might want to put the engine on a scope and see if you have alot of timing slop from a loose chain.
Mike
Mike
