Rover 4.0 Engine Dimensions
Old Feb 5, 2008 | 06:10 AM
Suagrtown Cabaret's Avatar
4th Gear
Default Rover 4.0 Engine Dimensions
Im kicking around a radical engine swap on a 97 Disco, and was wondering if any of you had a shop/tech manual that gave overall dimensions of the motor and how much it weighs?
Thanks
Old Feb 5, 2008 | 06:50 AM
Default RE: Rover 4.0 Engine Dimensions
Nope, but what are you thinking about installing?
Old Feb 5, 2008 | 08:26 AM
4th Gear
Bear with me on this one:
1. Marks 4WD makes motor mounts and tranny kits to put a small block Chevy in a Disco or a Pre-96 Rangie. Id rather have a Disco than a Rangie simply for its Jerry Can styling.
2. Im all but positive the mounts for a small block Chev and a Rat motor are the same.
3. My Chevy performance book says that the SBC and BBC and extremely simialr in external dimensions - something like 5" in width and maybe 2" in height - Weight is significantly different, but thats just a spring issue.
So - If I can get a SBC into a 97 Disco, then Im just wondering if I can fit a BBC in there also? If I knew how big the stock Rover moto was - I could determine it for sure.
Old Feb 5, 2008 | 09:56 AM
The one faqctor you may not have taken into consideration is the power issue. The tranny, t/case and diffs won't hold alot of torque.
Old Feb 26, 2008 | 07:29 PM
Landzu's Avatar
ORIGINAL: Suagrtown Cabaret
Thanks
Look here
http://www.v8engines.com/old-pages/T...4.htm#check-up
At top of page.
03discoman
Jan 12, 2010 10:56 PM
04BluDisco
Jun 30, 2009 11:31 AM
Emerson00
Dec 18, 2006 06:07 PM
Cavalry
Aug 27, 2006 01:35 PM
brad
Jan 2, 2005 10:12 AM
