Up-grade to electric fans....
Hi there, I need to know the normal tempeture on a bosh 4.6 litres engine. I just up-grade to electric fans but the a/c fan kick in around 208 and bring the temp down to 203. but when i turn the a/c the temp climb to 220 or more.... i just need to know the normal temp on this motor..... thanks
on
You have cost your self some big BUCKs for nothing.
Why did you change your fan, how many miles on your truck and what was the truck running at before you decided to do this.
You, by your temp numbers are now running way too hot./ Your t/stat starts to open at 180 and is fully open at 192, I rarely get above 204 or 205 even when driving in the mountains.
on
First, do your self a huge favor and get rid of that K&N air filter before it costs you a new MAF as well as a really dirty engine.
Your numbers are way to high and I would suggest you go see a radiator shop and see what they suggest as to possibly cleaning out your radiator.
How is your new fan set to come on, is it mutiple speeds and at what temp?
Maf sensor is about a year old, and knn is about 8mo Thanks for the advice................. The a/c fan kick in around 208f while the aditional electric fan turn on around 204f plus the fan cluth is back on the truck, the temp still high, but it stay around 204 and the maximum is 208 no more than that.... Yea the new t /stat get here on tuesday and i'm hooping to solve the problem...So far the oil is fine and im not loosing any coolant at all, so the engine still ok. I'm cheking with a radiator shop on wednesday to see what they said afther i swap the new t/stat... Thanks Mike!!!
Well, Letme just re-post on this issue....... I found out that my radiator is clug on the inside and don't think I can fush it... So the truck still running hot but never went to 220F againg since I clean the out side of the radiator with alot of water and a flash light to see if the light go tru the other side....
wilson96rr
05-31-2009 10:07 PM
