wheel spacer
RE: wheel spacer
Disco Mike is right, unless you really need them you probably should not use them. You can now find some on ebay for the Rover so try there if you want some cheap ones, they will be about $90 pair. Spacers are fine if you are going to change to a different offset that will still equal the factory offset, I have done that on my BMW. Went from low offset to high for the type of wheel I wanted to run, essentially I did not change the distance that the wheel actually sits in relation to the suspension.
I would say of you really wanted then you should be fine for street use but be prepared for a possible issue when you wheel it hard.
