ZF 6HP26 on Disco II?
Old Oct 24, 2007 | 10:25 PM
ajh's Avatar
ajh
Default ZF 6HP26 on Disco II?
Anyone considered swapping a ZF 6HP26 from a Disco III onto a II? Did you figure out if they're compatible mountings? I figure it could improve mileage a good 8% or so due to the 6-speed and the fact it is rated for 442ft/lb vs 280ft/lb of the ZF 4HP22 currently in the II. May even gain some of the 20hp the older torque converter eats up. The other option would be to fit the R380 5-speed which will handle 380ft/lb.
Old Oct 25, 2007 | 08:56 AM
Default RE: ZF 6HP26 on Disco II?
How would you deal with the ECU? The idea is great but I don't think it will fly.
Old Oct 25, 2007 | 09:49 AM
ajh's Avatar
ajh
Not sure yet, I figure there must be a compatible controller out there but will need to look into it some more.
socalrovershop
Jan 10, 2013 02:07 PM
