2017 Front Passenger Seat removal
Old Jan 28, 2025 | 12:17 PM
maviaman's Avatar
Default 2017 Front Passenger Seat removal
I lost my key under the fron passenger seat cavity. Any pointers on how to remove seat - easy/diff? or shall I try to remove the door sill and check if I can access the under seat from the passenger door side.
FYI - there is a big/deep cavity under passenger seat and things can easy slide into it
Old Jan 28, 2025 | 12:38 PM
CincyRovers's Avatar
It is just like removing any power seat. You'll have to undo all the bolts on the seat rails and disconnect all the electrical connectors. Also worth mentioning the the bottom seatbelt anchor is integrated into the seat on the L462.
Old Jan 28, 2025 | 12:53 PM
maviaman's Avatar
Thanks! I don't think I would need to remove the connectors as by moving the seat all the way forward I can reach the ky but not good enough to grab it... I think by unbolting the rails and lifting it about an inch (with connectors on) should be possible.
If I have to remove connectors I think better to disengage battery as there are airbags in seats...
Old Jan 28, 2025 | 01:15 PM
ponderosajack's Avatar
If you can reach the key but not grasp it I would first try something sticky on a stick or stiff flexible wire.
Like sticky tape with sticky side out. Or chewing gum. Or maybe a tube on a vaccuum.
disco96sd
Nov 19, 2024 11:01 AM
ReignRock
Jan 19, 2024 08:15 AM
NiteTrain
Feb 22, 2011 12:52 PM
Poisonego2010
Dec 11, 2010 06:16 PM
rover2003
Nov 7, 2007 09:53 AM
