Anyone running 33” tires?
#31
#32
#33
I doubt it. The rubbing seems to be from the front of the wheel well where the “venting” sticks in a bit. I don’t think you could space it out enough to clear the inner portion of the tire from still touching.
1979rover (08-09-2021)
#34
#35
No problem jacking only one wheel at a time. Spray a shot of lubricant on each end and they will pop right off and on. I did use a forked prybar - it was a golf divot repair tool. It will take longer to jack and remove the wheel than swap the rod. You could probably crawl under without removing the wheel but I’d want a jack to make sure no suspension movements while underneath.
willche (08-15-2021)
#36
275/55-20 are about 32 inch tires. That's the size many of us have gone to. Many brands and models come in this size.
You have to be careful for 2 things: Rubbing of the inner fender due to the increased diameter (which hasn't really been a problem with 32 inch tires), and rubbing of the knuckle to the inside of the tire.
#38
#39
The following 3 users liked this post by jimdigriz:
#40
