Battery Replacement Question
That said, the D5 battery is still strong and I use an Odyssey 20 Amp charger to maintain it at peak levels, given its age (I have two Odyssey batteries in my diesel truck). The D5 battery may surprise me and last a lot longer.
I was wondering about my 2017 Disco battery as well, so I checked the Repair Manual. It says if a new battery is installed:
I haven't found a battery supplier that lists a battery that fits the 2017 Disco... Manual says the battery spec is: AGM type, 90 Ah, 850 CCA, Reserve capacity 150 minutes.
- Using Land Rover approved diagnostic equipment, reset the battery monitoring system (BMS).
- Reset electric window one-touch facility. Power window up to hard stop, release switch, reapply and hold for 1 second, (relay in door will click). One touch should now work.
- Using suitable Land Rover diagnostic equipment calibrate the electric park brake and tailgate.
- Check the clock and navigation settings.
- Enter the audio unit preset radio frequencies.
ar077 (01-21-2021)
I didn't do anything special. just swapped it out.
Disco5tv (01-21-2021)
