Brembo banjo bolt crush washer size?
Old Oct 17, 2024 | 02:46 PM
462disco's Avatar
Default Brembo banjo bolt crush washer size?
Does anyone have the measurement for the crush washer for the front banjo bolts?
Called a few places and LR only sells the hose, bolt, and washers as one package. Swapping to the 6 pot calipers soon.
Thanks
Old Oct 20, 2024 | 05:50 PM
462disco's Avatar
Update - measured and you need two M10 washers per front caliper.
Old Nov 21, 2024 | 11:00 PM
462disco's Avatar
Final update -
Changed my calipers from the 4 piston to 6 piston brembos.
The crush washers are oblong and don't readily come off the brake line. Dealer said the washers are not sold separately, only with the entire brake line assembly. I kept it on and torqued to spec.. so far so good. No leaks visible.
231john
May 21, 2020 08:52 PM
skigolfnut
Aug 27, 2014 11:58 AM
focusontheworld
Oct 9, 2012 07:11 AM
penniwb
Jan 29, 2010 06:02 PM
Darover
Nov 5, 2008 02:36 PM
