Coolant for Discovery 5
Old Mar 7, 2023 | 03:03 PM
RichardinFL's Avatar
Default Coolant for Discovery 5
I need to buy coolant for my 2020 Discovery Landmark. My current coolant is Orange.
Could someone please advise (brand name, specs) or provide a link to which one I should be buying?
I was told This One would work, but I'm not sure as it says "GM Vehicles"
Thanks in advance!
Old Mar 7, 2023 | 04:24 PM
LR disco 5's Avatar
As it states in the owners manual use Havoline XLC 50/50 and mix with water. I couldn't find any of that in Canada so I went to the stealership and paid about 38 Cad which is around 27 Usd which isn't bad.
Old Mar 7, 2023 | 05:30 PM
Thank you LR Disco for your reply.
Could anyone pls confirm if THIS ONE is also OK?
Old Mar 7, 2023 | 05:37 PM
LR disco 5's Avatar
I wouldnt try Ive heard about it on other forums but I wouldn't try don't know how it would affect the engine but myy 2 cents
Old Mar 7, 2023 | 08:59 PM
Donc98's Avatar
Thanks in advance!
That is the one I used but the premixed 50/50 when I replaced the water pump, thermostat, and radiator last year on my 17. Also use the same fluid on my lr4.
Old Mar 10, 2023 | 07:00 AM
gmfain's Avatar
another choice is Delo XLC
https://buy.chevronlubricants.com/Br...B&gclsrc=aw.ds
Old Mar 12, 2023 | 06:44 PM
LR disco 5's Avatar
isnt delo for semi trucks??
Old Mar 13, 2023 | 02:56 PM
gmfain's Avatar
It is , but it is also XLC standard. I believe it would be fine.
I bet Pentosin make something too. I have not researched it.
Old Oct 20, 2024 | 06:51 AM
Rover06's Avatar
My low coolant light went on in my 2018 Disco Si6. Reservoir was well below the min marker. Lady i called at the dealership advised to top it off and wait to see if it drops again, although she was not a service advisor and i'm waiting to hear back from my service advisor on whether to bring it in right away (which i'm leaning towards doing). Will report back if i get it checked out.
I topped it off with the below Peak coolant (pink) which seemed to be a direct replacement for the Havoline XLC factory fill:
PEAK OAT Pink antifreeze PEAK OAT Pink antifreeze
Old Oct 22, 2024 | 06:41 PM
aforarun's Avatar
I bought two cans of 50/50 premix blue color Prestone Euro from Walmart . Seems to be doing just fine
