DEF Tip
Old 10-27-2018, 06:41 PM
turnbaugh's Avatar
Default DEF Tip
At 7000 miles started getting the DEF refill warnings.
Wife took it to the dealer in Austin and came home with a receipt for $180. I nearly had a stroke. They charge $28 for each two liter bottle. It holds 4.8 gals.
Called Dallas dealer. They do a full refill for $49.
Since then I found the same ISO certified DEF on Amazon for $20 for 2.5 gals. Audi sells the two liter bottles for $12.
Even though the D V cost $75K I guess the still want to screw you on the consumables.
Old 10-28-2018, 09:07 AM
2019D5's Avatar
Much better margins
Haven't popped the hood to check, but is the refill spot obvious and easily accessed?
Old 10-28-2018, 11:44 AM
turnbaugh's Avatar
Right side under the hood. Easy to find. Easy to fill with a funnel
2019D5 (10-29-2018)
Old 10-28-2018, 01:16 PM
Groucho123's Avatar
??Whats a DEF??
Old 10-28-2018, 04:47 PM
Received 1,465 Likes on 1,196 Posts
Diesel fluid additive
Groucho123 (10-28-2018)
Old 10-29-2018, 09:50 AM
Black 18 Disco's Avatar
Buy Peak DEF at Pep Boys and get two 2.5 gallon containers until the end of the month BOGO free. I think they are about $15 each and it meets the ISO requirements. Also includes a refill hose, so no funnel required.
2019D5 (10-29-2018)
Old 10-29-2018, 11:39 AM
1979rover's Avatar
^This +100.
Also, I think I got my last DEF at Walmart for $8 for 2.5 gallons
Old 10-29-2018, 11:23 PM
canon_mutant's Avatar
You should escalate this. It was highway robbery when Porsche/Audi charged $60 on the Cayenne and Q5.
Like others have said, the 2.5 gal jugs are cheap. Easy to do.
There is NO excuse for that charge.
Old 10-30-2018, 08:18 AM
SoCalWiley's Avatar
I picked some up at Walmart as well, do you know what ISO standard they have to meet?
Sure there is; they charge $60 because people will pay it without knowing any better.
Old 10-30-2018, 09:59 AM
1979rover's Avatar
Not specifically. But I read the label pretty carefully and it said it met manufacturer specifications, blah, blah.
I've now gone through two or three of them with zero issues.
Quick Reply: DEF Tip
