Diagnostic Tool for Discovery 5
this may help.
Oil Reset:
1 - sit in the drivers seat with all the doors and hood closed
2 - push the ignition button once, no foot on the brake, we do not want to start the vehicle (called position 2)
3 - with the door still closed, pop the hood with the hood release. This will bind on the door a little, but can be accomplished - just pull it.
4 - open the driver door and stay in the vehicle
5 - hold (depress) the gas and brake pedal for 60 seconds
6 - check the display - it should have reset and you are good to go from another 8000 miles (usually resets in about 15 seconds)
7 - close the hood
Oil Reset:
7 - close the hood
I have a TD6 2017.
Couldn't reset the service with the above procedure: car shows service reset but mileage remain 0.
I bought a Foxwell NT650 pro, (they send me elite) for test. The menu contains 2017 discovery but shows "no communication" when I try to use it to reset service.
However, when I use 2017+ New Range Rover model, I can get service reset same as what I get by pushing two pedals. But when I try to reset oil service, it reads "ECU not supported".
I think it is a diesel vehicle only issue as that there are two difference service reset option in the menu: service reset and oil service reset. I guess that the second one is the one we need to reset to get available mileage back.
I dont have much luck with the customer support, they are responding but kept saying that they would need to find a vehicle like mine to do trouble shoot. Well, TD6 barely exists in China...
